[Qgis-user] ManageR and Rpy2 in windows 7
Giovanni Manghi giovanni.manghi at gmail.com
Thu Aug 5 10:22:38 PDT 2010
if you used osgeo4w then install it with the same installer, it is in
the "Libs" section.
Be sure that the R binaries are also in the "path" environment variable
of windows.
cheers
-- Giovanni --
On Thu, 2010-08-05 at 18:24 +0200, Paco Ferri wrote:
>  Hi everybody
> I am a new user of Qgis. I have installed and loaded the plugin
> manageR and when I try to run it I get the message that Rpy2 can not
> be found, which I did install. Anybody has had the same problem?
> My computer is running on windows7 I do not know it that can be an
> issue.
> thanks in advance!
> Qgis-user mailing list
