[Qgis-user] shapefiles
Benoit EXIGE
benoit at exigesa.com
Fri Aug 6 23:46:03 PDT 2010
In QGIS the project CRS must be the same as all the rasters crs you
want to display. Furthermore you need to enable on-the-fly projection
to be able to display vector layers in different crs.
To display lat-lon I think the project crs must be one of the lat-lon
crs. This will imply that all your rasters must be in the same lat-lon
crs.
There is no, yet, on-the-fly projection for raster.
Also note that what you've done was only cosmetic and did not
reproject the vector files to the intended projection. For that you
need to explicitely reproject the vector files using the reproject
option of the vector menu.
Hope this help.
Benoit
Sent from my iPod
On 07 Aug 2010, at 1:37, "john" <jerasku at hotmail.com> wrote:
> hello all, I'm new to qgis and am having a problem getting a tiff
> file to display with all vector files at the same time. I'm using
> 1.5.0 on windows vista. also can any one tell me how to get all the
> layers' co-ordinates to display in longitude and latitude? I've
> tried changing all to wgs 84 in each layer's properties-general-
> specify crs but can not get co-ord capture to display in long,lat.
> any suggestions will be greatly appreciated.
> thanks in advance,
> j. rask
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100807/5fb95ced/attachment.html>
