[Qgis-user] Delete column in Attribute Table
Horst Düster horst.duester at kappasys.ch
Sat Aug 7 02:02:27 PDT 2010
Am 07.08.2010 10:52, schrieb Akhilesh Gan:
> All,
>    We have the Delete column feature in QGIS 1.4(Avilable in Attribute
> table and also Attribute properties) In Edit mode this button is not
> enabled. *How* *to* *delete* *column* *in* QGIS 1.4?
> Thanks
> Regard
>  Akhilesh
> Qgis-user mailing list
Which kind of data source do you use? When you use PostGIS you can drop
your column from your PG-Table. When you use file based data sources
take the table manager plugin.
Horst
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100807/f1d4973e/attachment.html>
