[Qgis-user] Map Composer
Andreas Neumann a.neumann at carto.net
Sat Aug 14 01:19:43 PDT 2010
You can manually remove layers or groups that you aren't interested in
by pressing the "x"-Button (this can be done by selecting the legend in
the canvas and using the "Item" tab to the right of the map canvas). By
default, only the currently visible layers will be included into the
legend. There is also an "Update" or "All" button if you want to update
to a new selection of visible layers.
Does this help/clarify things about the legend?
What version are you using? If you are using an older version (1.3 or
1.4) the legend may behave different compared to a current version (1.5
or dev-version).
Andreas
On 8/14/10 4:11 AM, Brett Adams wrote:
>  Hi Folks,
> When using the map composer, under Legend items, is it possible to
> show only the items loaded into in legend instead of everything that's
> loaded into the work space?
> Thanks heaps
