[Qgis-user] Map Composer
Brett Adams badams.spinifex at gmail.com
Sat Aug 14 01:26:00 PDT 2010
  Andrew,
Running V1.4
I was hoping to find a way that eliminated the need to manually delete
50 individual layers while keeping 5.
Thanks all the same.
BA
On 14/08/2010 4:19 PM, Andreas Neumann wrote:
> Hi,
> You can manually remove layers or groups that you aren't interested in
> by pressing the "x"-Button (this can be done by selecting the legend
> in the canvas and using the "Item" tab to the right of the map
> canvas). By default, only the currently visible layers will be
> included into the legend. There is also an "Update" or "All" button if
> you want to update to a new selection of visible layers.
> Does this help/clarify things about the legend?
> What version are you using? If you are using an older version (1.3 or
> 1.4) the legend may behave different compared to a current version
> (1.5 or dev-version).
> Andreas
> On 8/14/10 4:11 AM, Brett Adams wrote:
>>  Hi Folks,
>> When using the map composer, under Legend items, is it possible to
>> show only the items loaded into in legend instead of everything
>> that's loaded into the work space?
>> Thanks heaps
> Qgis-user mailing list
Brett Adams
Spinifex Geophysics
0438 861 974
SKYPE:brettadams_spinifex
