[Qgis-user] Announcing ProfileFromLine plugin
stefaan dondeyne stefaan_dondeyne at yahoo.co.uk
Tue Aug 17 05:44:18 PDT 2010
Hi Giovanni and Borys
- both many thanks for your advise
- so far I have been generating topographic transects using the SPRING (I use it mainly for DTM and for working with Satelite images)
- it would have been great if I could do it easily and straight in qGIS, which I use mainly with vector data - but OK for the time being I'll continue using SPRING for that matter
Cheers
Stefaan
_________________________________________________
Stefaan Dondeyne (PhD)
GSM +32 476 61 90 65 (Belgium) Mobile +258 82 89 295 64 (Mozambique)
Tel + 32 16 32 97 34 (Department Earth and Environmental Sciences - KU Leuven)_________________________________________________
http://www.panoramio.com/user/3497468?with_photo_id=25100300
http://www.mozambiqueflora.com/index.php http://micaia.org/centre/micaia_family.html
http://ees.kuleuven.be/
--- On Tue, 17/8/10, Borys Jurgiel <borysiasty at aster.pl> wrote:
Subject: Re: [Qgis-user] Announcing ProfileFromLine plugin
To: giovanni.manghi at gmail.com
Cc: "stefaan dondeyne" <stefaan_dondeyne at yahoo.co.uk>, qgis-user at lists.osgeo.org
Date: Tuesday, 17 August, 2010, 14:38
#yiv1509396459 p, #yiv1509396459 li {white-space:pre-wrap;}
Dnia wtorek 17 sierpnia 2010 o 14:28:26 Giovanni Manghi napisał(a):
> second advice: use the osgeo4w installer, it is different from what you
> may already know, but after a few tries it makes perfectly sense... as
> you have everything in may need in the same installer.
I'm not a windows user, but I'm afraid osgeo4w doesn't help in this particular case, as it's written here:
http://lists.osgeo.org/pipermail/qgis-user/2010-August/009351.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100817/98e1c14f/attachment.html>
