[Qgis-user] Announcing ProfileFromLine plugin
Giovanni Manghi giovanni.manghi at gmail.com
Tue Aug 17 05:48:41 PDT 2010
if the problem is installing the right version of shapely then "easy
install" is available also for windows
http://pypi.python.org/pypi/setuptools#windows
On Tue, 2010-08-17 at 12:44 +0000, stefaan dondeyne wrote:
> Hi Giovanni and Borys
> - both many thanks for your advise
> - so far I have been generating topographic transects using the
> SPRING (I use it mainly for DTM and for working with Satelite images)
> - it would have been great if I could do it easily and straight in
> qGIS, which I use mainly with vector data - but OK for the time being
> I'll continue using SPRING for that matter
> Cheers
> Stefaan
> _________________________________________________
> Stefaan Dondeyne (PhD)
> GSM +32 476 61 90 65 (Belgium) Mobile +258 82 89 295 64 (Mozambique)
> Tel + 32 16 32 97 34 (Department Earth and Environmental Sciences - KU
> Leuven)_________________________________________________
> http://www.panoramio.com/user/3497468?with_photo_id=25100300
> http://www.mozambiqueflora.com/index.php
> http://micaia.org/centre/micaia_family.html
> http://ees.kuleuven.be/
> --- On Tue, 17/8/10, Borys Jurgiel <borysiasty at aster.pl> wrote:
>         From: Borys Jurgiel <borysiasty at aster.pl>
>         Subject: Re: [Qgis-user] Announcing ProfileFromLine plugin
>         To: giovanni.manghi at gmail.com
>         Cc: "stefaan dondeyne" <stefaan_dondeyne at yahoo.co.uk>,
>         qgis-user at lists.osgeo.org
>         Date: Tuesday, 17 August, 2010, 14:38
>         Dnia wtorek 17 sierpnia 2010 o 14:28:26 Giovanni Manghi
>         napisaƂ(a):
>         > second advice: use the osgeo4w installer, it is different
>         from what you
>         > may already know, but after a few tries it makes perfectly
>         sense... as
>         > you have everything in may need in the same installer.
>         I'm not a windows user, but I'm afraid osgeo4w doesn't help in
>         this particular case, as it's written here:
>         http://lists.osgeo.org/pipermail/qgis-user/2010-August/009351.html
