[Qgis-user] Announcing ProfileFromLine plugin
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Tue Aug 17 12:57:07 PDT 2010
Hello all
I have uploaded a new version of this plugin. It will display a more
meaningful error message when the user doesn't have the minimum
version of Shapely or GEOS necessary to run it.
I also added a fix for the problem reported by Paolo:
"...BTW, if I run the Profile romLine without selecting a line (I know
this is wrong), I
get an error:
Errore durante l'esecuzione di codice Python:
 File "/home/paolo/.qgis/python/plugins/ProfileFromLine/ProfileFromLineDialog.py",
line 44, in accept
   params["interval"], self.ui.progressBar)
 File "/home/paolo/.qgis/python/plugins/ProfileFromLine/ProfileFromLine.py",
line
106, in create_profile_layer
AttributeError: 'NoneType' object has no attribute 'dataProvider'
This should be trapped, and a more meaningful error should be
displayed to the user...."
Now the plugin will only be active (selectable from the toolbar or the
plugins menu) if there is already a lines layer loaded in the map
canvas.
Thank you for testing it out
On Tue, Aug 17, 2010 at 1:48 PM, Giovanni Manghi
<giovanni.manghi at gmail.com> wrote:
> if the problem is installing the right version of shapely then "easy
> install" is available also for windows
> http://pypi.python.org/pypi/setuptools#windows
> On Tue, 2010-08-17 at 12:44 +0000, stefaan dondeyne wrote:
>> Hi Giovanni and Borys
>> - both many thanks for your advise
>> - so far I have been generating topographic transects using the
>> SPRING (I use it mainly for DTM and for working with Satelite images)
>> - it would have been great if I could do it easily and straight in
>> qGIS, which I use mainly with vector data - but OK for the time being
>> I'll continue using SPRING for that matter
>> Cheers
>> Stefaan
>> _________________________________________________
>> Stefaan Dondeyne (PhD)
>> GSM +32 476 61 90 65 (Belgium) Mobile +258 82 89 295 64 (Mozambique)
>> Tel + 32 16 32 97 34 (Department Earth and Environmental Sciences - KU
>> Leuven)_________________________________________________
>> http://www.panoramio.com/user/3497468?with_photo_id=25100300
>> http://www.mozambiqueflora.com/index.php
>> http://micaia.org/centre/micaia_family.html
>> http://ees.kuleuven.be/
>> --- On Tue, 17/8/10, Borys Jurgiel <borysiasty at aster.pl> wrote:
>>         From: Borys Jurgiel <borysiasty at aster.pl>
>>         Subject: Re: [Qgis-user] Announcing ProfileFromLine plugin
>>         To: giovanni.manghi at gmail.com
>>         Cc: "stefaan dondeyne" <stefaan_dondeyne at yahoo.co.uk>,
>>         qgis-user at lists.osgeo.org
>>         Date: Tuesday, 17 August, 2010, 14:38
>>         Dnia wtorek 17 sierpnia 2010 o 14:28:26 Giovanni Manghi
>>         napisał(a):
>>         > second advice: use the osgeo4w installer, it is different
>>         from what you
>>         > may already know, but after a few tries it makes perfectly
>>         sense... as
>>         > you have everything in may need in the same installer.
>>         I'm not a windows user, but I'm afraid osgeo4w doesn't help in
>>         this particular case, as it's written here:
>>         http://lists.osgeo.org/pipermail/qgis-user/2010-August/009351.html
> Qgis-user mailing list
___________________________ ___ __
Ricardo Garcia Silva
