[Qgis-user] project plan
Sajjad dosto.walla at gmail.com
Tue Aug 17 16:31:42 PDT 2010
Hello forum,
I have downloaded and installed the release version of QGis and started to
give it a try.
At the same time i would like to discuss some of the issues that i have in
my mind to make sure that the purpose can be served by QGis.
I have a project on operation research and i have to come up with some
optimized path for transportation. The path generation is based on
some heuristic algorithms. I want to visualize  those generated path on the
map of the district under operation.
The junction point of the road path can be retrieved from the
database(MySql) and i believe that it is possible from within QGis. The
nodes could be added or deleted
which will be reflected into the underlying database. When the nodes are
specified and finalized, i run the developed algorithm and show the
resulting path in the map.
I think i need a separate user interface based on Qt to edit nodes and its
parameters, The connected one/two directed edges. How do i connect it to
the QGis to show me the nodes in the map while i am editing and
eventually the finalized ouput of the path.
If QGis is too big for this project or the right tool to choose.
A suggestion will be very helpful to decide the formulation of this future
project.
Regards
Sajjad
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100818/513a39c0/attachment.html>
