[Qgis-user] Add a point
Benoit de Cabissole benoit at exigesa.com
Mon Aug 23 02:07:01 PDT 2010
Hi André,
One solution is as follows (you must have enabled the Numerical Vertex Edit
plugin):
- Enter edit mode on the point layer
- Add a point to the approximate coords, fill attributes, if any.
- Use Numerical Vertex Edit plugin
       - Click the newly added point with the red cross cursor
       - Then enter the correct coords
       - Cick ok
- Save edits
Hope this helps,
Benoit
  -----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org]On Behalf Of ALT SHN
  Sent: Monday, 23 August 2010 11:00
  To: qgis-user at lists.osgeo.org
  Subject: [Qgis-user] Add a point
  Hello List!
  I have a very simple question, in fact it's so simple i never thought of
it before!
  How can I add a point (in a vector layer) of known coordinates?
  For example, I have a layer of points called "Trees" and I want to add a
tree wich is located on a given X/Y coordinate. How can I give the
coordinate so that the new point is created on the exact location?
  Thanks in advance!
  Best Regards,
  André
  Associação Leonel Trindade
  SOCIEDADE DE HISTÓRIA NATURAL
  Apartado 25 2564-909 Torres Vedras Portugal
  Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres
Vedras
  Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto
do Ameal 2565-641 Ramalhal
  http://alt-shn.blogspot.com
  www.alt-shn.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100823/77e90b8f/attachment.html>
