[Qgis-user] Add a point
Giovanni Manghi giovanni.manghi at gmail.com
Mon Aug 23 02:13:08 PDT 2010
You can also add them with the "add delimited text layer" plugin.
On Aug 23, 2010 11:07 AM, "Benoit de Cabissole" <benoit at exigesa.com> wrote:
 Hi André,
One solution is as follows (you must have enabled the Numerical Vertex Edit
plugin):
- Enter edit mode on the point layer
- Add a point to the approximate coords, fill attributes, if any.
- Use Numerical Vertex Edit plugin
       - Click the newly added point with the red cross cursor
       - Then enter the correct coords
       - Cick ok
- Save edits
Hope this helps,
Benoit
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at ...
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100823/7ff71149/attachment.html>
