[Qgis-user] RE: Shapefile structure viewer and editor plugin
Alister Hood alister.hood at synergine.com
Wed Aug 25 21:03:27 PDT 2010
Thanks for this Benoit; it is fantastic.
We often need to extract the coordinates (and attributes) from a point shapefile, and put them in a spreadsheet.  This was one of two things I still did in a proprietary GIS, but your plugin gives me a much quicker and more straightforward way of doing it.
Have you considered displaying the CRS at the top?
Regards,
Alister
2010/8/24 Benoit de Cabissole <benoit at exigesa.com>
>  Hello List,
> I've created a simple plugin that allows to view the structure of a
> shapefile (X-, Y-coords alongside its attributes) and while at it I've also
> added the capability to edit the geometry and attributes and save back to
> the shapefile.
> A corollary is that if you want to add a point by typing its coords you can
> do it with the plugin (as André aka ALT SHN has suggested). You can even
> create a new shapefile in QGIS and use the plugin to type in coords and
> attributes or paste them from the clipboard.
> Points, lines and polygons shapefiles can be manipulated.
> BUT, I feel it is a quite dangerous plugin to release in a public repo
> because of the potential damages bad edits can do on a shapefile!
> I would thus be very grateful if the most intrepid amongst you could test
> it and give comments on its usefulness...
> The plugin is available at the address below:
> http://www.bc-consult.com/free/bccshpv.html
> Cheers,
> Benoit
> Qgis-user mailing list
