[Qgis-user] Shapefile structure viewer and editor plugin
ALT SHN
i.geografica at alt-shn.org
Tue Aug 24 15:30:27 PDT 2010
Hi Benoit!
This is a great plugin! I tested it on one point shapefile (8003 objects)
and all went fine!
Although I understand your concern about making it public, I think it's
extremely usefull (at least for me it is) and it would be a shame not to put
it on a public repository... Besides it even has a fair documentation, so I
think newbies would be ok.
Anyway, great tool! Thanks!
Best Regards,
André
2010/8/24 Benoit de Cabissole <benoit at exigesa.com>
> Hello List,
> I've created a simple plugin that allows to view the structure of a
> shapefile (X-, Y-coords alongside its attributes) and while at it I've also
> added the capability to edit the geometry and attributes and save back to
> the shapefile.
> A corollary is that if you want to add a point by typing its coords you can
> do it with the plugin (as André aka ALT SHN has suggested). You can even
> create a new shapefile in QGIS and use the plugin to type in coords and
> attributes or paste them from the clipboard.
> Points, lines and polygons shapefiles can be manipulated.
> BUT, I feel it is a quite dangerous plugin to release in a public repo
> because of the potential damages bad edits can do on a shapefile!
> I would thus be very grateful if the most intrepid amongst you could test
> it and give comments on its usefulness...
> The plugin is available at the address below:
> http://www.bc-consult.com/free/bccshpv.html
> Cheers,
> Benoit
> Qgis-user mailing list
Associação Leonel Trindade
SOCIEDADE DE HISTÓRIA NATURAL
Apartado 25 2564-909 Torres Vedras Portugal
Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto do
Ameal 2565-641 Ramalhal
http://alt-shn.blogspot.com
www.alt-shn.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100824/b4a40e01/attachment.html>
