[Qgis-user] Re: georeference plugin, maximum distortion needed, and black background
Roland Hill Roland.Hill at FourWindsTechnology.com.au
Wed Feb 3 14:42:47 PST 2010
You can make the black surrounds to your warped image transparent by
right clicking on the layer, choosing properties, then selecting
Transparency. Add a new entry to the Transparent Pixel List using the
button with the star, then put 0 in for Red, Green and Blue (or 255 for
white backgrounds).
Roland
mtnbiketrail at zzz.com wrote:
> I'm trying to geo-reference some rasters.
> I'm not sure which algorithm to use to get maximum match with known
> GCPs, these rasters need to be distorted a lot. I thought tps and
> cubic would be best. Can anyone tell me which algorithm is best?
> Also, when the raster is placed(georeference completed), the
> background outside the original raster is black, not transparent like
> I would expect. I doubt I can trim the modified raster without losing
> GCPs. I can make the raster transparent, but I don't like the
> results.  Is there a solution to the black background?
> Once I am satisfied with geo-referenced rasters, I can trace vector
> polylines inside QGIS. Or is there a better way? Using a vector
> drawing program like Inkscape or Adobe Illustrator?
> I'm potentially dealing with a lot of data, so am looking for the best
> way.
> thanks,
> Tom
> using 1.3
> Qgis-user mailing list
