[Qgis-user] Mapping landslides
Alex Mandel tech_dev at wildintellect.com
Fri Feb 26 17:04:32 PST 2010
Inkscape works fine for importing that pdf (And almost any pdf assuming
it not a rasterized pdf) At most you'll need to select and group several
pieces into a single object and save it.
Most of these symbols are actually either very specific in size or are
line and fill types. Converting to SVG will only help with point
symbols. In the case of the symbols that are specific in size a png or
other non scalable graphic might be better to match the rules, SVG
should also work you'll just have always double check that you've got it
scaled correctly.
I know we were working on allowing user created lines and fills but I'm
not sure how far we've come and know you'll need at least version 1.4 to
start accessing that ability.
Thanks,
Alex
On 02/26/2010 04:34 PM, Mike Toews wrote:
> Hi Bob,
> Sure is possible. First, you need to make the icon into an SVG file.
> If you have Adobe Illustrator, you can open the PDF you provided a
> link to, isolate or copy the graphic and save it as SVG. Inkscape is
> another good (free) tool, but it cannot open PDFs, so you will need to
> trace the graphic.
> Once it is an SVG, just place the file into the QGIS svg directory
> somewhere (e.g., C:\OSGeo4W\apps\qgis-unstable\svg), and it will be
> available as a point symbol next time you open QGIS. The symbol size
> can be based on a numeric attribute of the layer by setting Properties
>> Symbology > Drawing by field > Area scale (the location of this
> option depends on which version of QGIS, I'm using 1.4.0).
> -Mike
> On 26 February 2010 10:31, Bob and Deb <bobdebm at gmail.com> wrote:
>> Hello all,
>> I am interested in mapping landslides using the symbols found here:
>> http://ngmdb.usgs.gov/fgdc_gds/geolsymstd/fgdc-geolsym-sec17.pdf .
>> Can I do this with qgis?  If I can do this in qgis, I would also like
>> to have qgis scale some of these symbols so that they are proportional
>> to the size and direction of the landslide.  How do I do that?
>> Thanks in advance!
>> Bob
