[Qgis-user] Re: labelling point layer
Martin Dobias
wonder.sk at gmail.com
Thu Jan 7 00:59:49 PST 2010
Hi Piotr,
this functionality is planned, but I can't give you currently any
estimate when to expect it.
Regards
Martin
2010/1/6 Piotr Pachół <piotr.pachol at wodgik.katowice.pl>:
> Hello Martin,
> Is it possible to add one function in your labeling plugin ?:
> It means the possibility of choosing one of layer attributes as a field
> where an angle for labels is kept.
> It would be very usefull for point layers and perhaps for polygon layers.
> For instance I must visualize map with address numbers. Each number should
> be rotated differently.
> Now there is only possibility to rotate all labels with the same angle.
> Regards,
> Piotr
