[Qgis-user] fill patterns in map printing
Marco Hugentobler marco at hugis.net
Wed Jan 20 23:40:16 PST 2010
Hi Markus
At the moment, there is no layer transprency setting in the new symbology. I'm
planing to add that soon.
Regards,
Marco
Am Donnerstag, 21. Januar 2010 05.39:03 schrieb Markus Nater:
> I was playing around now quite some time with the svgfill feature. it's
> a great feature! Nevertheless I experience obstacles, making parts of
> the svg-grafic transparent. The only way I managed to come close to
> transparency is by drawing an object in inkscape and setting its filling
> to an opacity-value (alpha-value) of ca. 100. Then, imported to qgis,
> underlaying layer shine trough.... but unfortunately it's only
> semi-transparent.
> cheers
> markus
> Marco Hugentobler schrieb:
> > Hi Markus
> >> 2. The new symbology is not yet supported in print composers legend....
> >> I guess, thats may be coming in a later version?
> > Yes. For now, you could add a composer picture and move it over the
> > legend as a workaround.
> > Regards,
> > Marco
> > Am Mittwoch, 20. Januar 2010 13.15:42 schrieb Markus Nater:
> >> Hi Marco, Hi Andreas
> >> Thanks a lot for your assistance, so nice!
> >> I am experimenting at the moment with the vector fill patterns. (that's
> >> exactly what I am looking for).
> >> There are two problems though I don't know yet how to overcome:
> >> 1. When I create a line in a 16*16 icon in inkscape and want to use with
> >> SVGFill the background is just white - it would be great to make it
> >> transparent, so one could see between the lines what layer is
> >> underneath.
> >> Cheers
> >> Markus
> >> Andreas Neumann schrieb:
> >>> Hi Markus,
> >>> I don't know exactly what pattern you want to apply. Those are
> >>> fill-patterns not stroke-dashings or stroke-patterns?
> >>> Do you have access to the latest svn-version.
> >>> As Marco said, he just implemented vector fill patterns (with the new
> >>> symbology-engine) - but it was just recently checked in - so it's not
> >>> part of the QGIS 1.4 release. Because it is new, it also not documented
> >>> yet - but we can assist you if you need help.
> >>> You need to compile yourself or install the QGIS-dev version from
> >>> OSGeo4Win.
> >>> As Marco said - you cannot print to PDF yet without a workaround. You
> >>> would need to print to .ps and then convert the .ps to pdf if you use
> >>> the new vector fills.
> >>> Hope this helps,
> >>> Andreas
> >>> On Wed, January 20, 2010 10:30 am, Markus Nater wrote:
> >>>> nobody any advice how to print out a map with line fill patterns that
> >>>> are not too thin? (to visualize two layers that are above each other)
> >>>> I am desperate, should hand in some maps and can't get over this
> >>>> obstacle... so I probably will have to rebuild all my projects in
> >>>> arcview just in order to print out a decent map...!
> >>>> cheers
> >>>> mark
> >>>> _______________________________________________
> >>>> Qgis-user mailing list
> >>>> Qgis-user at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
Technical Advisor QGIS Project Steering Committee
