[Qgis-user] How to create a slope analysis?
Benoit de Cabissole benoit at exigesa.com
Sat Jan 23 23:55:49 PST 2010
Hi Micha,
Micha Silver wrote:
> I can verify the problem outlined below with the Contours plugin. On
> Windows, the Shapely python library will only install under a regular
> (i.e. registered in the Win registry) python installation. But the
> Contours plugin only searches in the QGIS python installation. So
> shapely.geometry is never found.
> Any ideas how to fix this are welcome. For example, can Shapely
be added
> to the OSGeo4W install like matlibplot is?
> Regards,
> Micha
I've had a similar problem and posted about it last week.
The solution I've found is to use the contour sub-menu under the
raster menu (in QGIS 1.4, OSGEO4W).
It seems to be very similar to the contour plugin.
HTH
Benoit
QGIS 1.4 - OSGEO4W - WinXP
