[Qgis-user] How to create a slope analysis?
Micha Silver micha at arava.co.il
Sun Jan 24 00:57:17 PST 2010
On 24/01/2010 09:55, Benoit de Cabissole wrote:
> Hi Micha,
> Micha Silver wrote:
>> I can verify the problem outlined below with the Contours plugin. On
>> Windows, the Shapely python library will only install under a regular
>> (i.e. registered in the Win registry) python installation. But the
>> Contours plugin only searches in the QGIS python installation. So
>> shapely.geometry is never found.
>> Any ideas how to fix this are welcome. For example, can Shapely
> be added
>> to the OSGeo4W install like matlibplot is?
>> Regards,
>> Micha
> I've had a similar problem and posted about it last week.
Thanks for reminding me! So just install GDALTools plugin and you have it.
Regards,
Micha
> The solution I've found is to use the contour sub-menu under the
> raster menu (in QGIS 1.4, OSGEO4W).
> It seems to be very similar to the contour plugin.
> HTH
> Benoit
> QGIS 1.4 - OSGEO4W - WinXP
> Qgis-user mailing list
> This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
