[Qgis-user] Use render caching where possible to speed up redraws
John C. Tull jctull at gmail.com
Mon Jan 25 16:54:04 PST 2010
I've played around with allowing this on my own builds. The result is crashes, at least with some projects, when you try to resize the application window. I've not tried to debug this, but it seems to be a qt issue. It is true of both carbon and cocoa qt-4.6, likely older qt as well.
John
On Jan 25, 2010, at 12:06 PM, William Kyngesburye wrote:
> I don't know about the reason, but I just wanted to point out that it's more general: same on Snow, and same for Qt 4.6 Cocoa (the 1.4 builds use Qt 4.5 Carbon).  Also, it's the whole "Render behavior" group of options that is disabled (display added layers by default, number of features to draw, render caching).
> On Jan 25, 2010, at 1:49 PM, Kurt Menke wrote:
>> Hello,
>> Is there any reason that “Use render caching where possible to speed up redraws” would not be available on the Mac Leopard stand alone version of QGIS 1.4?
>> Kurt
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
> Qgis-user mailing list
