[Qgis-user] Re: QR barcodes
maning sambale
emmanuel.sambale at gmail.com
Thu Jan 28 18:37:42 PST 2010
Just curious, for what purpose? I am aware of how qr codes are used
in virtually anything in japan.
I want to create a similar inventory system for our printed map.
On Fri, Jan 29, 2010 at 3:40 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> mtnbiketrail at zzz.com wrote:
>> I saw the walking-papers.org website. Here is my question:
>> Can anyone point me in the direction on how this would be done inside
>> QGIS? How would I generate a QR code for a printed map made from inside
>> QGIS. Or does it only work with certain map programs? The QR barcode
>> generators I found seem to be stand alone programs.
>> thanks,
>> Tom
> Sure you'll need to find an open source library for encoding the
> barcodes. One example might be http://qrcode.sourceforge.jp/
> Then you can write a qgis plugin that integrates into the app. Basically
> a prompt that asks for the information need to create the barcode and
> then places the results on the map composer or map window (kinda like
> the north arrow).
> Note you could cheat for now and create it oustide the app and make it a
> north arrow or just drop it on top of the final map.
> Alex
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
