[Qgis-user] QGIS1.4.0 With GRASS - Windows Installer
Alex Mandel tech_dev at wildintellect.com
Fri Jan 29 12:23:42 PST 2010
Jürgen E. Fischer wrote:
> Hi Bruno,
> On Fri, 29. Jan 2010 at 08:23:22 +0100, Bruno Friedmann wrote:
>> Dear Kumaran, as you can build for windows.
>> Is there any chance you can try to build a 64 native windows package ?
>> This can help many people too.
> AFAIK the OSGeo4W packages work fine on 64bit.
> Jürgen
There is a side issue to this that came up on the R-sig-geo mailing list
and I referred them to OSGeo4w. Users of 64bit R are looking for a 64bit
version of gdal (which would also likely be a requirement for 64bit
QGIS). Specifically they need a 64bit gdal for use with 64bit rdgal that
wraps gdal allowing import of data into R. This might apply to R based
QGIS plugins too if someone happens to install 64bit R.
Just wanted to put that on the radar, I'll probably bring it up on the
OSGeo4W list too.
Alex
