[Qgis-user] Segmentation fault...
Luigi Castro Cardeles luigi.cardeles at gmail.com
Mon Mar 1 13:13:48 PST 2010
i recompiled qgis 1.4.0 and keep with the same problem. QGIS run but not
python plugin, i also get the same error message about sip version.
When i run cmake .. and configure (c), the dialog show some msg but it goes
so fast that i can't read. There is some way to slowdown that message or is
this logged on a file? Sorry but i don't know cmake very well.
[]'s
2010/3/1 Micha Silver <micha at arava.co.il>
> Luigi Castro Cardeles wrote:
>> Thanks Martin,
>> i use a compiled qgis.
>> For Fedora Users, i think that this update comes with kde-4.4.0 updates.
>> []'s
>>  I also have a self compiled qgis 1.4.  After updating to the new PyQt4
> and sip (also updated qt and qt-x11 packages) last week, I recompiled, and
> still get the segfault. And again, after switching to xfce, QGIS starts
> fine. Under Gnome, QGIS will start only if run as super user. So my guess is
> that the problem is some interaction between Gnome and Qt in the newer
> packages.
>> 2010/3/1 Martin Dobias <wonder.sk <http://wonder.sk>@gmail.com <
>> http://gmail.com>>
>>    On Mon, Mar 1, 2010 at 5:23 PM, Luigi Castro Cardeles
>>    <luigi.cardeles at gmail.com <mailto:luigi.cardeles at gmail.com>> wrote:
>>    > Hi list,
>>    > maybe there are other problem (relate to pyqgis):
>>    > Não foi possível carregar PyQGIS.
>>    > Suporte à Python vai ser desabilitado.
>>    > Traceback (most recent call last):
>>    >   File "", line 1, in
>>    > RuntimeError: the sip module implements API v7.0 but the
>>    qgis.core module
>>    > requires API v6.0
>>    This looks like you've updated sip package in your system, however
>>    qgis python module still awaits older version.
>>    - if you run self-compiled qgis, just recompile it and install again.
>>    It should adapt to newer sip version
>>    - if you run qgis from a distribution package, request an updated
>>    package from the packager
>>    - you could downgrade sip package and all packages that depend on it
>>    (PyQt, PyKDE) but I wouldn't recommend that as it might break your
>>    system
>>    Martin
>> This mail was received via Mail-SeCure System.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Micha Silver
> Arava Development Co. +972-52-3665918
> http://surfaces.co.il
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100301/d04940ed/attachment.html>
