[Qgis-user] Segmentation fault...
Micha Silver micha at arava.co.il
Mon Mar 1 22:40:56 PST 2010
On 03/01/2010 10:54 PM, Martin Dobias wrote:
> On Mon, Mar 1, 2010 at 7:16 PM, Micha Silver<micha at arava.co.il>  wrote:
>> Luigi Castro Cardeles wrote:
>>> Thanks Martin,
>>> i use a compiled qgis.
>>> For Fedora Users, i think that this update comes with kde-4.4.0 updates.
>>> []'s
>> I also have a self compiled qgis 1.4.  After updating to the new PyQt4 and
>> sip (also updated qt and qt-x11 packages) last week, I recompiled, and still
>> get the segfault. And again, after switching to xfce, QGIS starts fine.
>> Under Gnome, QGIS will start only if run as super user. So my guess is that
>> the problem is some interaction between Gnome and Qt in the newer packages.
> To check whether this hypothesis is correct, you can try to run some
> other Qt application(s) within your gnome environment.
Other Qt apps run OK ( Qt linguist for example, and qtconfig-qt4 ).
Another funny point: when I ssh -X into the problematic Fedora computer
from an Ubuntu machine, and start qgis (thru the tunnel) then it starts
fine! Probably using the Qt on the remote Ubuntu machine?
> Another reason of the crash could be a malfunctioning plugin...
I renamed the whole ~/.qgis to test that earlier. No help...
> Martin
> This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
