[Qgis-user] Join Attributes - no Shapefile createt (QGIS 1.4)
Carson Farmer carson.farmer at gmail.com
Tue Mar 9 14:23:33 PST 2010
Hello Claas,
>> Whenn I want to join a DBF-File to a Shapefile, there was no new
>> Shapefile createt. Look at the Example! In QGIS 1.3 it runs with the
>> same files!
>> The Example:
>> I want th join the table "termine.dbf" to the Shapefile "LKE_MUE".
>> Target Vektorlayer:        LKR_MUE
>> Target Join Field:         GEM_ID
>> Join Data > Join DBF File: termine.dbf
>> join field:                GEM_ID
>> OutputShapefile:           test.shp
>> But there was no Shapefile createt! The same at QGIS 1.3: Shapefile was
>> createt!
>> please test it with the example-Files in attachment!
Tested with attached shapefile and dbf file, however, I suspect it has
something to do with the encoding of your shapefile (how was it
created?), because while this file does not work, other shapefiles
(using for example UTF-8) work fine, including other shapefiles joined
with your dbf file.
Can you provide any further details?
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation
National University of Ireland, Maynooth,
http://www.carsonfarmer.com/
