[Qgis-user] Re: Join Attributes - no Shapefile createt (QGIS 1.4)
Claas Leiner claas.leiner at eschenlaub.de
Wed Mar 10 13:04:01 PST 2010
Thanks for answers,
when I openend the termine.dbf with OpenOffice.org, delete the dbf-infos
in the column-heads, save the file as *.odt and then save the file as
*.dbf (utf8), I can join the termine.dbf. The encoding was the problem,
I think.
Claas
Dr.-Ing. Claas Leiner
Praxis für Landschaft, Vegetation und freie Geoinformationssysteme
Wilhelmshöher Allee 304 E
34131 Kassel
Tel. 0561/6026527
http://www.eschenlaub.de/landveg
Bernd Vogelgesang schrieb:
>> Tested with attached shapefile and dbf file, however, I suspect it has
>> something to do with the encoding of your shapefile (how was it
>> created?), because while this file does not work, other shapefiles
>> (using for example UTF-8) work fine, including other shapefiles joined
>> with your dbf file.
>> Can you provide any further details?
>> Carson
> Hi Claas and the others,
> this shapefile was created by me (nice surprise to find it as an issue
> here ;) )
> I digitized it from a WMS-Layer with QGIS 1.4 OSGEO4W-Installation on XP
> in UTF-8 with the first 3 table columns.
> The other data columns were added in OpenOffice Calc and several
> corrections of the dbf were made in Calc as well. Can this be the reason?
> Did do this more often and haven't had problems before.
> Is there sth particular stored within the shape file itself about the
> database structure that is now leading to the malfunction? (No idea
> about the inner anatomy of shapes)
> If this is not the case, could it be then some kind of data corruption
> caused by compressing for sending by email? (just a wild guess)
> Bernd
> Qgis-user mailing list
