[Qgis-user] Edit UI
Einar Guðsteinsson einsigu at simnet.is
Tue Mar 16 12:23:46 PDT 2010
This was easy. And I managed todo what I needed exept for one thing. One of
my attribute is Value map. Was trying to go for combobox there. Any hint on
how I can managed to get my values in the combobox?
Einar
Sent: Tuesday, March 16, 2010 11:11 AM
To: "Richard Duivenvoorde" <rdmailings at duif.net>
Cc: "EinarGuðsteinsson" <einsigu at simnet.is>; <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Edit UI
> designing forms with qt-designer is not that hard. Even I know how to do
> it - and I am not a C++ programmer. You have to make sure that the widget
> is compatible with the data type and that the widget names correspond with
> the attribute column names.
> The other tricky part is to use layouts and spacers: grid and form layout.
> This helps to ensure that your forms can be resized and the widgets in the
> layout will resize as well. Sometimes it may be frustrating if you invest
> a lot of time to arrange widgets - then you apply a layout and it
> rearranges a lot ...
> All the rest is not really complicated.
> Andreas
> On Tue, March 16, 2010 7:21 am, Richard Duivenvoorde wrote:
>> Einar Guðsteinsson wrote:
>>> Ouch, one dev tool more to learn.... when day will be 26 hours :-)  Can
>>> I use action or something else to set default value?  one field is
>>> string with date and I want today always to be automaticly filled in.
>> Hi Einar,
>> 26 hours to learn qt-designer etc is maybe not enough. But it's nice to
>> know and using it in combination with a python plugin gives probably
>> what you want.
>> another option is
>> http://linfiniti.com/2009/11/creating-dynamic-forms-a-new-feature-headed-for-qgis-1-4/
>> which gives you without ui-file very very simple input forms (which
>> according the article you can even then manipulate using python (plugin).
>> Not sure about the last part...
>> Regards Richard Duivenvoorde
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
