[Qgis-user] CRS for a start
Werner Macho werner.macho at gmail.com
Mon Mar 22 11:32:57 PDT 2010
big +1 from me also - allthough it sounds after a "not so easy"
implementation ..
but that sounds like I would expect it to work also ..
regards
Werner
> +1, i also think your suggestions make working with qgis more
> user-friendly.
> Regards,
>  Otto
> > +1 on each of a-c.
> > On Mar 21, 2010, at 3:01 PM, Milena Nowotarska wrote:
> > > Hi All,
> > > I guess that many users work not only with WGS84 projection (which
> > > is set by default in QGIS) so I would like to discuss with you a
> > > change in QGIS behaviour on loading a layer.
> > > In my opinion it would be good if QGIS:
> > > a) set the projection for a project file/working environment from
> > > the first loaded layer if it has the projection information
> > > b) prompt for projection information if the layer does not have it
> > > c) inform in a popup window when the projection of next loaded
> > > layers do not match the projection already set in the working
> > > environment (when reprojection on the fly is not ticked)
> > > Now, as I personally use metric reference systems (2180, 2176,
> > > 2177), every time I open a layer, I have to set the proper CRS and,
> > > on the other tab change units from degrees to meters. If I forget
> > > to do that, I will get strange scale and strange measurement output.
> > > At least the change form geographic to metric projection should
> > > force the change of units. Otherwise we won't be able to say that
> > > QGIS is user friendly ;)
> > > What in your opinion should be the most expected behaviour in a
> > > good GIS system?
> > > I mean in QGIS I can open now a holiday photo, go to layer
> > > properties and get an impresion from it's metadata, that it is
> > > already georeferenced:
> > > "Layer Spatial Reference System:
> > > +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
> > > which is of course not true. But we have to think about novice GIS
> > > users who might either go dizzy or get bad habits.
> > > Best,
> > > Milena
> > > Milena Nowotarska
> > > http://wiki.osgeo.org/wiki/Milena_Nowotarska
> > > http://quantum-gis.pl/
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100322/2e58c370/attachment.sig>
