[Qgis-user] CRS for a start
Goyo goyodiaz at gmail.com
Mon Mar 22 13:40:41 PDT 2010
El dom, 21-03-2010 a las 23:01 +0100, Milena Nowotarska escribió:
> Hi All,
> I guess that many users work not only with WGS84 projection (which is
> set by default in QGIS) so I would like to discuss with you a change
> in QGIS behaviour on loading a layer.
> In my opinion it would be good if QGIS:
> b) prompt for projection information if the layer does not have it
You can configure QGIS to do this. Edit > Options, SRC, select "Prompt
for CRS". I think this should be the default as it is more informative
for new users.
