[Qgis-user] Compiling QGIS on Ubuntu
Alex Mandel tech_dev at wildintellect.com
Tue May 4 12:14:48 PDT 2010
Borys Jurgiel wrote:
>> FindGSL.cmake: gsl-config not found. Please set it manually.
>> GSL_CONFIG=GSL_CONFIG-NOTFOUND
> install libgsl0-dev
>> -- Could not find GRASS
> Run ccmake and set GRASS_PREFIX to proper directory
> (probably /usr/lib/grass64)
>> -- SIP executable is missing!
>> -- SIP header file is missing!
> install: sip4, python-sip, python-sip-dev
>> -- PyQt4 development files are missing!
> Are pyqt4-dev-tools installed?
> If you still get errors, just look for packages related to the missing
> components (including -dev packages)
On an Ubuntu(or debian box) there's a nice little tool to make this easier.
sudo apt-get build-dep qgis
That will grab all the build dependencies for qgis all at once and
automatically. This of course assumes that you have a recent version of
qgis available to you via the repositories and for that I suggest you
add the ubuntugis repo to your list.
https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
Enjoy,
Alex
