[Qgis-user] Compiling QGIS on Ubuntu
Borys Jurgiel borysiasty at aster.pl
Tue May 4 11:04:12 PDT 2010
> FindGSL.cmake: gsl-config not found. Please set it manually.
> GSL_CONFIG=GSL_CONFIG-NOTFOUND
install libgsl0-dev
> -- Could not find GRASS
Run ccmake and set GRASS_PREFIX to proper directory
(probably /usr/lib/grass64)
> -- SIP executable is missing!
> -- SIP header file is missing!
install: sip4, python-sip, python-sip-dev
> -- PyQt4 development files are missing!
Are pyqt4-dev-tools installed?
If you still get errors, just look for packages related to the missing
components (including -dev packages)
