[Qgis-user] Python support will be disabled error after importing an external plugin
Laura Poggio
laura.poggio at gmail.com
Wed May 5 06:02:08 PDT 2010
Dear all,
I tried to compile the development version of QGIS with some extra plugins,
namely the OTB plugin<http://wiki.orfeo-toolbox.org/index.php/Quantum_GIS_plugins>.
I am using a 64bit fedora machine. The compilation of QGIS was fine without
any problems. Below the options I used:
- cmake -DCMAKE_INSTALL_PREFIX:PATH=/home/myuser/bin/qgis/qgis_trunk
-DGRASS_PREFIX:PATH=/usr/local/grass-6.5.svn/
-DGDAL_LIBRARY:STRING=/usr/lib64/libgdal.so ..
- make -j
- make install
QGIS was running fine, with many plugins, such as GRASS one. The OTB plugin
was not appearing.
According to the instructions for the installation in the OTB website I
called QGIS after adding the export of OTB libraries:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$HOME/bin/otb/built/bin:$; qgis
and I get the following error message. Afterwards QGIS is working and OTB
plugin is visible and working, but python is not enabled.
Couldn't load PyQGIS.
Python support will be disabled.
File "", line 1, in
ImportError: No module named qgis.core
Python version:
2.6 (r26:66714, Nov 3 2009, 17:33:18)
[GCC 4.4.1 20090725 (Red Hat 4.4.1-2)]
QGIS version:
1.5.0-Trunk 'Trunk', 13417M
Python path:
['/python', '/home/lp6220/.qgis/python',
'/home/lp6220/.qgis/python/plugins', '/python/plugins',
'/usr/lib/python2.6/site-packages/pupynere-1.0.13-py2.6.egg',
'/usr/lib64/python26.zip', '/usr/lib64/python2.6',
'/usr/lib64/python2.6/plat-linux2', '/usr/lib64/python2.6/lib-tk',
'/usr/lib64/python2.6/lib-old', '/usr/lib64/python2.6/lib-dynload',
'/usr/lib64/python2.6/site-packages',
'/usr/lib64/python2.6/site-packages/Numeric',
'/usr/lib64/python2.6/site-packages/PIL',
'/usr/lib64/python2.6/site-packages/gtk-2.0',
'/usr/lib64/python2.6/site-packages/wx-2.8-gtk2-unicode',
'/usr/lib/python2.6/site-packages']
I tried to add some of the paths listed in the message to LD_LIBRARY_PATH
without any success for the moment.
Thank you very much in advance for any suggestions.
Laura
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100505/e3e627a7/attachment.html>
