[Qgis-user] Re: Installation of QGIS using Ubuntu Synaptic Package Manager
Pedro Roma
pedroroma1982 at gmail.com
Wed May 5 06:44:51 PDT 2010
Greetings Borys
> First, you should see the line below in cmake output:
> Found GRASS: /usr/local/grass-6.4.0svn
> Then "make" should attempt to compile the grass support with such output among
> other plugins:
> Linking CXX shared library libqgisgrass.so
> [ 68%] Built target qgisgrass
> Linking CXX shared module libgrassprovider.so
> [ 68%] Built target grassprovider
> Linking CXX shared module libgrassrasterprovider.so
> [ 68%] Built target grassrasterprovider
> Linking CXX shared module libgrassplugin.so
> [ 96%] Built target grassplugin
> Unfortunely I didn't saved the text into a log file.
> Finally, "make install" installs the compiled .so libraries (e.g.
> libgrassplugin.so) in /lib/qgis/ within your destination folder, so usually in
> /usr/local/lib/qgis/
> At that folder I only have :
libgrassplugin.so and libgrassprovider.so
libqgisgrass.so, libgrassrasterprovider.so are not there.
> If they are there, probably something is wrong with the library path. Do you
> see other c++ plugins like evis, North Arrow or Scale bar on the plugin list
> in the manager?
> yes I do. They are all there.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100505/78cf4ff2/attachment.html>
