[Qgis-user] qgis compiling error
Pierre Chevalier Géologue pierrechevaliergeol at free.fr
Thu May 6 07:29:26 PDT 2010
Hello,
I had the same kind of error, also on debian testing. I tried many
different things, and it eventually worked out, I'm not exactly sure
what exactly worked...  It may be a mess between sip and sip4 packages?
Here are the last things I did, as root, just before it worked,
according to my /root/.bash_history:
    apt-get install gdal-bin libgdal1-dev libgeos-dev proj libgdal-doc
    python-dev libgsl0-dev g++ libjasper-dev libtiff4-dev subversion
    libsqlite3-dev sqlite3 ccache make libpq-dev flex bison cmake
    txt2tags python-qt4 python-qt4-dev python-sip4 sip4 python-sip4-dev
    apt-get install cmake
    apt-get install grass libgrass-dev
    apt-get install grass grass-dev
    cd /usr/local/bin
    sudo ln -s /usr/bin/ccache gcc
    sudo ln -s /usr/bin/ccache g++
    apt-get install build-essential g++ subversion
In case it helps...  After that, I could successfully ccmake .. , make,
make install... it works!
But I ran into another problem: I'll put this on another thread.
A+
Pierre
flavio rigolon claviota:
> Hi all,
>  I'm trying to compile qgis (on debian testing). During the ccmake ..
> I've got this error:
>  CMake Error at cmake/FindSIP.cmake:52 (MESSAGE):
>    Could not find SIP
>  Call Stack (most recent call first):
>    CMakeLists.txt:358 (FIND_PACKAGE)
> My system is up-to-date (this morning).
> I've found another thread:
> http://osgeo-org.1803224.n2.nabble.com/sip-not-working-with-py-2-6-td4467899.html
> wich contains the same object, but I can't figure out.
> Any suggestion will be appreciated. Thanks in advance.
> regards
> flavio
____________________________________________________________________________
Pierre Chevalier Géologue EI
    Mesté Duran
    32100 Condom
  Tél+fax  :    09 75 27 45 62
                05 62 28 06 83
		06 37 80 33 64
  Émail  :   pierrechevaliergeolCHEZfree.fr
  icq#   :   10432285
  skype  :   pierre.chevalier1967
  http://pierremariechevalier.free.fr/pierre_chevalier_geologue
