[Qgis-user] qgis compiling error
flavio rigolon flavio.rigolon at gmail.com
Thu May 6 08:37:12 PDT 2010
2010/5/6 Pierre Chevalier GĂ©ologue <pierrechevaliergeol at free.fr>
> Hello,
Hi Pierre,
> I had the same kind of error, also on debian testing. I tried many
> different things, and it eventually worked out, I'm not exactly sure what
> exactly worked...  It may be a mess between sip and sip4 packages?
> Here are the last things I did, as root, just before it worked, according
> to my /root/.bash_history:
>   apt-get install gdal-bin libgdal1-dev libgeos-dev proj libgdal-doc
>  python-dev libgsl0-dev g++ libjasper-dev libtiff4-dev subversion
>   libsqlite3-dev sqlite3 ccache make libpq-dev flex bison cmake
>   txt2tags python-qt4 python-qt4-dev python-sip4 sip4 python-sip4-dev
>   apt-get install cmake
>   apt-get install grass libgrass-dev
>   apt-get install grass grass-dev
>   cd /usr/local/bin
>   sudo ln -s /usr/bin/ccache gcc
>   sudo ln -s /usr/bin/ccache g++
>   apt-get install build-essential g++ subversion
I've followed your suggestions but the error is the same.....thanks anyway.
flavio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100506/5b556efa/attachment.html>
