[Qgis-user] qgis segfault when resizing main window
Pierre Chevalier Géologue pierrechevaliergeol at free.fr
Thu May 6 07:48:15 PDT 2010
Hello,
I get regularly a segmentation fault when I resize the main qgis window,
only if there is some data displayed.  My platform is a debian testing
machine, up-to-date, with the debian.gfoss.it repository.
Usually, when I work, I always have several windows of any kind open,
and I keep on moving and resizing windows, without any trouble,
including qgis, that I use very often.
Last week or so, I began to get some problems, qgis was crashing in some
cases.  It got quite annoying.  I was running qgis 1.4, then I switched
to 1.5.  I secretly hoped that someone could have solved this bug, so I
got the source and compiled qgis from source (I had some trouble with
sip and python, but it got solved).
Now I am running version 1.5 revision 13427.
There is no special message from the xterm where I launched qgis from:
    pierre at duran:~$ /usr/local/bin/qgis
    Python support ENABLED :-)
    /usr/lib/python2.5/site-packages/osgeo/gdal.py:99:
    DeprecationWarning: gdal.py was placed in a namespace, it is now
    available as osgeo.gdal
      DeprecationWarning)
    Loaded : Plugin Installer (package: plugin_installer)
    Loaded : SelectPlus Menu (package: selectplus)
    Loaded : Images to Shapefile (package: imagestoshape)
    Loaded : PostGIS manager (package: postgis_manager)
    Loaded : Azimuth and Distance Plugin (package: qgsAzimuth)
    Loaded : autosave (package: autosave)
    Loaded : ShowHideImg (package: imgshowhide)
    Loaded : Elevation (package: elevation)
    Erreur de segmentation
The last messages means translation fault, in French.
If there is no data loaded, nothing happens, I am able to resize the
windows in any direction.  Whenever I load some data, then it crashes as
soon as I resize the window.
Has anyone got an idea?  Known bug?
Thanks in advance.
A+
Pierre
____________________________________________________________________________
Pierre Chevalier Géologue EI
    Mesté Duran
    32100 Condom
  Tél+fax  :    09 75 27 45 62
                05 62 28 06 83
		06 37 80 33 64
  Émail  :   pierrechevaliergeolCHEZfree.fr
  icq#   :   10432285
  skype  :   pierre.chevalier1967
  http://pierremariechevalier.free.fr/pierre_chevalier_geologue
