[Qgis-user] qgis segfault when resizing main window
John C. Tull jctull at gmail.com
Fri May 7 08:43:37 PDT 2010
Hi Pierre,
This is an issue I have brought up in the past on irc, but apparently there is not a bug filed (I thought there was, but could not find it). I had believed this to be an issue exclusive to the Mac platform, but apparently not. I am not sure if this is qgis or qt, but it is a big problem. Please file a bug if you don't mind.
http://trac.osgeo.org/qgis/newticket
You might also see this bug, which I still experience.
http://trac.osgeo.org/qgis/ticket/2483
From what I can tell, a single raster image on the canvas causes bug 2483 to occur. The crash that you describe occurs when a single vector file is loaded. So, different issues depending on the source data type.
Regards,
John
On May 6, 2010, at 7:48 AM, Pierre Chevalier Géologue wrote:
> Hello,
> I get regularly a segmentation fault when I resize the main qgis window, only if there is some data displayed.  My platform is a debian testing machine, up-to-date, with the debian.gfoss.it repository.
> Usually, when I work, I always have several windows of any kind open, and I keep on moving and resizing windows, without any trouble, including qgis, that I use very often.
> Last week or so, I began to get some problems, qgis was crashing in some cases.  It got quite annoying.  I was running qgis 1.4, then I switched to 1.5.  I secretly hoped that someone could have solved this bug, so I got the source and compiled qgis from source (I had some trouble with sip and python, but it got solved).
> Now I am running version 1.5 revision 13427.
> There is no special message from the xterm where I launched qgis from:
>   pierre at duran:~$ /usr/local/bin/qgis
>   Python support ENABLED :-)
>   /usr/lib/python2.5/site-packages/osgeo/gdal.py:99:
>   DeprecationWarning: gdal.py was placed in a namespace, it is now
>   available as osgeo.gdal
>     DeprecationWarning)
>   Loaded : Plugin Installer (package: plugin_installer)
>   Loaded : SelectPlus Menu (package: selectplus)
>   Loaded : Images to Shapefile (package: imagestoshape)
>   Loaded : PostGIS manager (package: postgis_manager)
>   Loaded : Azimuth and Distance Plugin (package: qgsAzimuth)
>   Loaded : autosave (package: autosave)
>   Loaded : ShowHideImg (package: imgshowhide)
>   Loaded : Elevation (package: elevation)
>   Erreur de segmentation
> The last messages means translation fault, in French.
> If there is no data loaded, nothing happens, I am able to resize the windows in any direction.  Whenever I load some data, then it crashes as soon as I resize the window.
> Has anyone got an idea?  Known bug?
> Thanks in advance.
> A+
> Pierre
> ____________________________________________________________________________
> Pierre Chevalier Géologue EI
>   Mesté Duran
>   32100 Condom
> Tél+fax  :    09 75 27 45 62
>               05 62 28 06 83
> 		06 37 80 33 64
> Émail  :   pierrechevaliergeolCHEZfree.fr
> icq#   :   10432285
> skype  :   pierre.chevalier1967         http://pierremariechevalier.free.fr/pierre_chevalier_geologue     ____________________________________________________________________________
> Qgis-user mailing list
