[Qgis-user] qgis & Debian testing
Gary Smith
gary.smith.rsa at gmail.com
Thu May 6 09:24:32 PDT 2010
I have installed the version 1.5 from the gfossit repository. I am not
sure how this version was compiled but I cannot get a version compiled
with Python2.6.
So although I have a compiled version it also has a number of
segmentation faults. The ones that I am most concerned with relate to
the GdalTools.
When I try to compile from source I also come up against the sip problem
which ultimately seems to be that the sipconfig module cannot be found.
I cannot downgrade to python 2.5 without killing the rest of my system.
A sad state of affairs. :-(
Gary
On 06/05/2010 18:00, qgis-user-request at lists.osgeo.org wrote:
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Re: qgis compiling error (flavio rigolon)
> Message: 1
> Date: Thu, 6 May 2010 17:37:12 +0200
> From: flavio rigolon<flavio.rigolon at gmail.com>
> Subject: Re: [Qgis-user] qgis compiling error
> To: Pierre Chevalier G?ologue<pierrechevaliergeol at free.fr>
> Cc: qgis-user<qgis-user at lists.osgeo.org>
> Message-ID:
> <s2w2ce45db01005060837sbee72a0wb3efc83e4b293257 at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> 2010/5/6 Pierre Chevalier Géologue<pierrechevaliergeol at free.fr>
>> Hello,
> Hi Pierre,
>> I had the same kind of error, also on debian testing. I tried many
>> different things, and it eventually worked out, I'm not exactly sure what
>> exactly worked... It may be a mess between sip and sip4 packages?
>> Here are the last things I did, as root, just before it worked, according
>> to my /root/.bash_history:
>> apt-get install gdal-bin libgdal1-dev libgeos-dev proj libgdal-doc
>> python-dev libgsl0-dev g++ libjasper-dev libtiff4-dev subversion
>> libsqlite3-dev sqlite3 ccache make libpq-dev flex bison cmake
>> txt2tags python-qt4 python-qt4-dev python-sip4 sip4 python-sip4-dev
>> apt-get install cmake
>> apt-get install grass libgrass-dev
>> apt-get install grass grass-dev
>> cd /usr/local/bin
>> sudo ln -s /usr/bin/ccache gcc
>> sudo ln -s /usr/bin/ccache g++
>> apt-get install build-essential g++ subversion
> I've followed your suggestions but the error is the same.....thanks anyway.
> flavio
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20100506/5b556efa/attachment-0001.html
> End of Qgis-user Digest, Vol 51, Issue 7
