[Qgis-user] qgis & Debian Testing
Gary Smith gary.smith.rsa at gmail.com
Fri May 7 09:12:39 PDT 2010
Hi Paolo,
Thanks for the assistance.
I downloaded the ver 1.5 deb packages and after a bit of problem with
the gqis & qgis-common inter-dependency issue I managed to get
everything installed. Now however I have the following problem:
Couldn't load SIP module.
Python support will be disabled.
   File "", line 1, in
ImportError: No module named sip
Python version:
2.6.5 (r265:79063, Mar 18 2010, 23:59:47)
[GCC 4.4.3]
QGIS version:
1.5.0-Trunk 'Trunk', 13426M
Python path:
['/usr/share/qgis/python', '/home/gary/.qgis/python',
'/home/gary/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
'/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
'/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
'/usr/lib/python2.6/dist-packages/PIL',
'/usr/lib/python2.6/dist-packages/gst-0.10',
'/usr/lib/pymodules/python2.6', '/usr/lib/pymodules/python2.6/gtk-2.0',
'/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
'/usr/local/lib/python2.6/dist-packages']
Any ideas?
Rgds
Gary
On 07/05/2010 08:44, qgis-user-request at lists.osgeo.org wrote:
> Send Qgis-user mailing list submissions to
> 	qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>     1. qgis&  Debian testing (Gary Smith)
>     2. Re: qgis&  Debian testing (Paolo Cavallini)
>     3. Vectorial do Raster (Nikos Dumakis)
>     4. Re: qgis compiling error (Pierre Chevalier G?ologue)
>     5. Re: Vectorial do Raster (Micha Silver)
>     6. Re: qgis compiling error (Thomas Gratier)
>     7. Re: Qgis-user Digest, Vol 51, Issue 7 (Sajid Iqbal)
>     8. RE: Re: Qgis-user Digest, Vol 51, Issue 7 (Kumaran Narayanaswamy)
> Message: 1
> Date: Thu, 06 May 2010 18:24:32 +0200
> From: Gary Smith<gary.smith.rsa at gmail.com>
> Subject: [Qgis-user] qgis&  Debian testing
> To: qgis-user at lists.osgeo.org
> Message-ID:<4BE2ED40.2030103 at gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> I have installed the version 1.5 from the gfossit repository. I am not
> sure how this version was compiled but I cannot get a version compiled
> with Python2.6.
> So although I have a compiled version it also has a number of
> segmentation faults. The ones that I am most concerned with relate to
> the GdalTools.
> When I try to compile from source I also come up against the sip problem
> which ultimately seems to be that the sipconfig module cannot be found.
> I cannot downgrade to python 2.5 without killing the rest of my system.
> A sad state of affairs.  :-(
> Gary
>> Today's Topics:
>>      1. Re: qgis compiling error (flavio rigolon)
>> Message: 1
>> Date: Thu, 6 May 2010 17:37:12 +0200
>> From: flavio rigolon<flavio.rigolon at gmail.com>
>> Subject: Re: [Qgis-user] qgis compiling error
>> To: Pierre Chevalier G?ologue<pierrechevaliergeol at free.fr>
>> Cc: qgis-user<qgis-user at lists.osgeo.org>
>> Message-ID:
>> 	<s2w2ce45db01005060837sbee72a0wb3efc83e4b293257 at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> 2010/5/6 Pierre Chevalier Géologue<pierrechevaliergeol at free.fr>
>>> Hello,
>> Hi Pierre,
>>> I had the same kind of error, also on debian testing. I tried many
>>> different things, and it eventually worked out, I'm not exactly sure what
>>> exactly worked...  It may be a mess between sip and sip4 packages?
>>> Here are the last things I did, as root, just before it worked, according
>>> to my /root/.bash_history:
>>>     apt-get install gdal-bin libgdal1-dev libgeos-dev proj libgdal-doc
>>>    python-dev libgsl0-dev g++ libjasper-dev libtiff4-dev subversion
>>>     libsqlite3-dev sqlite3 ccache make libpq-dev flex bison cmake
>>>     txt2tags python-qt4 python-qt4-dev python-sip4 sip4 python-sip4-dev
>>>     apt-get install cmake
>>>     apt-get install grass libgrass-dev
>>>     apt-get install grass grass-dev
>>>     cd /usr/local/bin
>>>     sudo ln -s /usr/bin/ccache gcc
>>>     sudo ln -s /usr/bin/ccache g++
>>>     apt-get install build-essential g++ subversion
>> I've followed your suggestions but the error is the same.....thanks anyway.
>> flavio
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20100506/5b556efa/attachment-0001.html
>> End of Qgis-user Digest, Vol 51, Issue 7
> Message: 2
> Date: Thu, 06 May 2010 18:35:26 +0200
> From: Paolo Cavallini<cavallini at faunalia.it>
> Subject: Re: [Qgis-user] qgis&  Debian testing
> To: Gary Smith<gary.smith.rsa at gmail.com>
> Cc: qgis-user at lists.osgeo.org
> Message-ID:<4BE2EFCE.9050006 at faunalia.it>
>> with Python2.6.
>> the GdalTools.
> are you on 32 or 64 bit?
> As you know, testing is a moving target, so old packages (even a few days) can give a
> lot of trouble.
> You can try this:
> http://int.faunalia.it/~paolo/debian/
> not apt-gettable, though.
> All the best.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100507/595a9242/attachment.html>
