[Qgis-user] qgis & Debian Testing
Paolo Cavallini cavallini at faunalia.it
Mon May 10 12:51:05 PDT 2010
Gary Smith ha scritto:
> I downloaded the ver 1.5 deb packages and after a bit of problem with
> the gqis & qgis-common inter-dependency issue I managed to get
> everything installed. Now however I have the following problem:
> Couldn't load SIP module.
> Python support will be disabled.
You're right, some modules from unstable are needed. I'll sort out the issue ASAP. In
the meantime, if someone can understand which modules, please tell us. I'll put up a
README as soon as the issue will be solved.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
