[Qgis-user] qgis & Debian Testing
Gary Smith
gary.smith.rsa at gmail.com
Tue May 11 08:58:17 PDT 2010
Hello Paolo,
I think that the problem actually exists with Python in Debian Squeeze.
Python 2.6.5 does NOT support the sipconfig module which prevents me
compiling from source.
I assume that it is also has problems with other Python modules. If you
are able to build QGIS with Python 2.5 then I would be happy - I think.
Rgds
Gary
On 10/05/2010 21:51, Paolo Cavallini wrote:
> Gary Smith ha scritto:
>> I downloaded the ver 1.5 deb packages and after a bit of problem with
>> the gqis& qgis-common inter-dependency issue I managed to get
>> everything installed. Now however I have the following problem:
>> Couldn't load SIP module.
>> Python support will be disabled.
> You're right, some modules from unstable are needed. I'll sort out the issue ASAP. In
> the meantime, if someone can understand which modules, please tell us. I'll put up a
> README as soon as the issue will be solved.
> All the best.
