[Qgis-user] QGIS Python startup error - Incompatible SIP module
Gary Sherman gsherman at geoapt.com
Sat May 8 08:08:33 PDT 2010
On Sat, May 8, 2010 at 4:16 AM, James Meyer <jamesm at lantic.net> wrote:
> I recently ran into an error while starting my QGIS application. Based on
> the errors below, I assume this is after I manually updated my SIP libraries
> to version 9.10.
> At startup of QGIS an error is displayed saying that Python cannot be
> started and will be disabled.
> The following detail is added to the error:
> RuntimeError: the sip module implements API v7.0 to v7.1 but the
> PyQt4.QtCore module requires API v6.0
> This error also prevents me from re-building and installing QGIS from
> source. The same error displays at 93% of insalling:
> File “/usr/bin/pyuic4″, line 3, in
> import PyQt4.uic.pyuic
> File “/usr/lib/pymodules/python2.6/PyQt4/uic/pyuic.py”, line 4, in
> from PyQt4 import QtCore
> I’ve tried removing SIP completely and downloading the QGIS dependencies
> from scratch, but the error persists.
> Any suggestions on what I should do?
> I am running Ubuntu 9.10 32bit
> Thanks
> James
Looks like you may have to rebuild (or upgrade) PyQt to a more recent version.
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Desktop GIS Book:
 *http://desktopgisbook.com
-Geospatial Consulting & Hosting:
 *http://geoapt.com
"We work virtually everywhere"
