[Qgis-user] Installing QGIS on CentOS?
tlange at gwdg.de tlange at gwdg.de
Mon May 10 13:31:13 PDT 2010
-- Accidently I replied just to Gerry. But now correctly also to qgis user
list... :)
Hi Gerry,
if I remember right, I had no problems at all getting compiled the gdal,
geos and proj libs required by Postgis, which I also compiled from sources
as well as probably Qgis. Just make sure to get the correct versions. Here
I think you'll find everything about the necessary dependencies:
http://download.osgeo.org/qgis/doc/manual/qgis-1.4.0_coding-compilation_guide_en.pdf
I qick-found also an elder document, which however seems it was a nice
install guide:
http://ergodd.zoo.ox.ac.uk/eden/etc/helpfiles/install_en.pdf
Cheers,
Torsten
> I'm resurrecting this thread... It'd be real nice if there were a methof
> to reduce the work needed to make QGIS work on CentOS.
> Getting it to work in Fedora has always been pretty straightforward.
> CentOS, however, follow RHEL which is much more stable than, e.g, Fedora.
> We're trying to install from source now. I'm not sure it's
> uncomplicated...
> gerry
> Torsten Lange wrote:
>> Hi Bruce,
>> months ago I wanted to install qgis on centos (5.2) and also did not
>> find
>> adapted packages. The only solution I found was compiling the required
>> things
>> by myself. This however was smooth and without complications. Ok, the
>> mentioned system is 32bit, don't know about 64... For most of the
>> dependencies
>> (e.g. Qt-libs) packages are probably available somewhere. Gdal, geos and
>> proj
>> would be the compile candidates.
>> Torsten
>> Am Mittwoch, 12. August 2009 06:18:06 schrieb Bob Bruce:
>>> I've developed some python plugins on Windows and wanted to test them
>>> on
>>> Linux before I shared them. My home Linux system is CentOS.
>>> So I tried installing QGIS via the Fedora RPM and found a long list of
>>> dependencies that had to be installed first.
>>> Is there a way to get the whole environment up and running quickly so
>>> that I can get on with working with QGIS?
>>> thanks,
>>>              Bob Bruce
>>> The output from the RPM run goes like this:
>>> [root at mappingnerd tmp]# rpm -ivh qgis-1.0.1-1.fc9.x86_64.rpm
>>> warning: qgis-1.0.1-1.fc9.x86_64.rpm: Header V3 DSA signature: NOKEY,
>>> key ID ed00d312
>>> error: Failed dependencies:
>>>          gpsbabel is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libICE.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libQtCore.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libQtGui.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libQtNetwork.so.4()(64bit) is needed by
>>>          libQtSql.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libQtSvg.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libQtXml.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libSM.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libX11.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libXcursor.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libXext.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libXfixes.so.3()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libXi.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libXinerama.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libXrandr.so.2()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libXrender.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libc.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libc.so.6(GLIBC_2.2.5)(64bit) is needed by
>>>          libc.so.6(GLIBC_2.3.4)(64bit) is needed by
>>>          libc.so.6(GLIBC_2.4)(64bit) is needed by
>>>          libdl.so.2()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libdl.so.2(GLIBC_2.2.5)(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libexpat.so.1()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libfontconfig.so.1()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libfreetype.so.6()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libgcc_s.so.1()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libgcc_s.so.1(GCC_3.0)(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libgdal.so.1()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libgeos_c.so.1()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libglib-2.0.so.0()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libgsl.so.0()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libgslcblas.so.0()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libgthread-2.0.so.0()(64bit) is needed by
>>> qgis-1.0.1-1.fc9.x86_64 libm.so.6()(64bit) is needed by
>>>          libm.so.6(GLIBC_2.2.5)(64bit) is needed by
>>>          libpng12.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libpq.so.5()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libproj.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libpthread.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libpthread.so.0(GLIBC_2.2.5)(64bit) is needed by
>>>          librt.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libsqlite3.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libstdc++.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>          libstdc++.so.6(CXXABI_1.3)(64bit) is needed by
>>>          libstdc++.so.6(CXXABI_1.3.1)(64bit) is needed by
>>>          libstdc++.so.6(GLIBCXX_3.4)(64bit) is needed by
>>>          libstdc++.so.6(GLIBCXX_3.4.9)(64bit) is needed by
>>>          libz.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Gerry Creager -- gerry.creager at tamu.edu
> Texas Mesonet -- AATLT, Texas A&M University
> Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
> Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
