[Qgis-user] Installing QGIS on CentOS?
Gerald Creager gerry.creager at tamu.edu
Mon May 10 14:30:48 PDT 2010
Torsten, all:
Thanks for the suggestions. Between me, and someone smarter than I am at
resolving dependencies, we're going now. I've always appreciated the
capabilities of QGIS, and I'll admit to frustration at not being able to
run it easily on an enterprise distribution. I understand the nature of
developing to newer, better releases and code, but I also have to live
with "really stable" in my environment.
That said, thank you all for your help and for a great piece of software.
Gerry
tlange at gwdg.de wrote:
> -- Accidently I replied just to Gerry. But now correctly also to qgis user
> list... :)
> Hi Gerry,
> if I remember right, I had no problems at all getting compiled the gdal,
> geos and proj libs required by Postgis, which I also compiled from sources
> as well as probably Qgis. Just make sure to get the correct versions. Here
> I think you'll find everything about the necessary dependencies:
> http://download.osgeo.org/qgis/doc/manual/qgis-1.4.0_coding-compilation_guide_en.pdf
> I qick-found also an elder document, which however seems it was a nice
> install guide:
> http://ergodd.zoo.ox.ac.uk/eden/etc/helpfiles/install_en.pdf
> Cheers,
> Torsten
>> I'm resurrecting this thread... It'd be real nice if there were a methof
>> to reduce the work needed to make QGIS work on CentOS.
>> Getting it to work in Fedora has always been pretty straightforward.
>> CentOS, however, follow RHEL which is much more stable than, e.g, Fedora.
>> We're trying to install from source now. I'm not sure it's
>> uncomplicated...
>> gerry
>> Torsten Lange wrote:
>>> Hi Bruce,
>>> months ago I wanted to install qgis on centos (5.2) and also did not
>>> find
>>> adapted packages. The only solution I found was compiling the required
>>> things
>>> by myself. This however was smooth and without complications. Ok, the
>>> mentioned system is 32bit, don't know about 64... For most of the
>>> dependencies
>>> (e.g. Qt-libs) packages are probably available somewhere. Gdal, geos and
>>> proj
>>> would be the compile candidates.
>>> Torsten
>>> Am Mittwoch, 12. August 2009 06:18:06 schrieb Bob Bruce:
>>>> I've developed some python plugins on Windows and wanted to test them
>>>> on
>>>> Linux before I shared them. My home Linux system is CentOS.
>>>> So I tried installing QGIS via the Fedora RPM and found a long list of
>>>> dependencies that had to be installed first.
>>>> Is there a way to get the whole environment up and running quickly so
>>>> that I can get on with working with QGIS?
>>>> thanks,
>>>>              Bob Bruce
>>>> The output from the RPM run goes like this:
>>>> [root at mappingnerd tmp]# rpm -ivh qgis-1.0.1-1.fc9.x86_64.rpm
>>>> warning: qgis-1.0.1-1.fc9.x86_64.rpm: Header V3 DSA signature: NOKEY,
>>>> key ID ed00d312
>>>> error: Failed dependencies:
>>>>          gpsbabel is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libICE.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libQtCore.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libQtGui.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libQtNetwork.so.4()(64bit) is needed by
>>>>          libQtSql.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libQtSvg.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libQtXml.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libSM.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libX11.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libXcursor.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libXext.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libXfixes.so.3()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libXi.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libXinerama.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libXrandr.so.2()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libXrender.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libc.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libc.so.6(GLIBC_2.2.5)(64bit) is needed by
>>>>          libc.so.6(GLIBC_2.3.4)(64bit) is needed by
>>>>          libc.so.6(GLIBC_2.4)(64bit) is needed by
>>>>          libdl.so.2()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libdl.so.2(GLIBC_2.2.5)(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libexpat.so.1()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libfontconfig.so.1()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libfreetype.so.6()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libgcc_s.so.1()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libgcc_s.so.1(GCC_3.0)(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libgdal.so.1()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libgeos_c.so.1()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libglib-2.0.so.0()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libgsl.so.0()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libgslcblas.so.0()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libgthread-2.0.so.0()(64bit) is needed by
>>>> qgis-1.0.1-1.fc9.x86_64 libm.so.6()(64bit) is needed by
>>>>          libm.so.6(GLIBC_2.2.5)(64bit) is needed by
>>>>          libpng12.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libpq.so.5()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libproj.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libpthread.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libpthread.so.0(GLIBC_2.2.5)(64bit) is needed by
>>>>          librt.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libsqlite3.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libstdc++.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>>>          libstdc++.so.6(CXXABI_1.3)(64bit) is needed by
>>>>          libstdc++.so.6(CXXABI_1.3.1)(64bit) is needed by
>>>>          libstdc++.so.6(GLIBCXX_3.4)(64bit) is needed by
>>>>          libstdc++.so.6(GLIBCXX_3.4.9)(64bit) is needed by
>>>>          libz.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Gerry Creager -- gerry.creager at tamu.edu
>> Texas Mesonet -- AATLT, Texas A&M University
>> Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
>> Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
