[Qgis-user] Probably an easy question...
Gerald Creager gerry.creager at tamu.edu
Mon May 10 15:15:45 PDT 2010
With qgis 1.4.0 running, I'm attempting to open shapefiles with a
projection using a Texas Statewide Mapping System (nominally EPSG 3081)
in meters, and WGS84 lon/lat (EPSG 4326), in degrees.
Apparently, I can't do that, though: I can't see the TSMS data overlaid
on the WGS84 data. It's been awhile since I'd used qgis, and I'm going
to try to look at docs tonight, but if someone's got a quick and dirty
hint, it'd be appreciated.
Thanks, gerry
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
