[Qgis-user] Probably an easy question...
Giovanni Manghi giovanni.manghi at gmail.com
Mon May 10 15:21:50 PDT 2010
you have to enable the "on the fly reprojection" checkbox in the project
properties.
cheers
-- Giovanni --
On Mon, 2010-05-10 at 17:15 -0500, Gerald Creager wrote:
> With qgis 1.4.0 running, I'm attempting to open shapefiles with a
> projection using a Texas Statewide Mapping System (nominally EPSG 3081)
> in meters, and WGS84 lon/lat (EPSG 4326), in degrees.
> Apparently, I can't do that, though: I can't see the TSMS data overlaid
> on the WGS84 data. It's been awhile since I'd used qgis, and I'm going
> to try to look at docs tonight, but if someone's got a quick and dirty
> hint, it'd be appreciated.
