[Qgis-user] Probably an easy question...
Gerald Creager gerry.creager at tamu.edu
Mon May 10 15:36:57 PDT 2010
Giovanni, all,
I got a note from Jurgen reminding me of that. I'll reread the docs, I
promise.  Thanks for the help!
gerry
Giovanni Manghi wrote:
> Hi,
> you have to enable the "on the fly reprojection" checkbox in the project
> properties.
> cheers
> -- Giovanni --
> On Mon, 2010-05-10 at 17:15 -0500, Gerald Creager wrote:
>> With qgis 1.4.0 running, I'm attempting to open shapefiles with a
>> projection using a Texas Statewide Mapping System (nominally EPSG 3081)
>> in meters, and WGS84 lon/lat (EPSG 4326), in degrees.
>> Apparently, I can't do that, though: I can't see the TSMS data overlaid
>> on the WGS84 data. It's been awhile since I'd used qgis, and I'm going
>> to try to look at docs tonight, but if someone's got a quick and dirty
>> hint, it'd be appreciated.
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
