[Qgis-user] Probably an easy question...
Thomas Wahlmüller thomas.wahlmueller at gmx.net
Mon May 10 15:41:07 PDT 2010
Hi
just in case you also use raster files:
on the fly projection currently only works with vector. so you have to
project other data to the projection your raster is using or you have to
reproject the raster (gdal --> warp)
greets
thomas
Am 11.05.2010 00:21, schrieb Giovanni Manghi:
> Hi,
> you have to enable the "on the fly reprojection" checkbox in the project
> properties.
> cheers
> -- Giovanni --
> On Mon, 2010-05-10 at 17:15 -0500, Gerald Creager wrote:
>> With qgis 1.4.0 running, I'm attempting to open shapefiles with a
>> projection using a Texas Statewide Mapping System (nominally EPSG 3081)
>> in meters, and WGS84 lon/lat (EPSG 4326), in degrees.
>> Apparently, I can't do that, though: I can't see the TSMS data overlaid
>> on the WGS84 data. It's been awhile since I'd used qgis, and I'm going
>> to try to look at docs tonight, but if someone's got a quick and dirty
>> hint, it'd be appreciated.
> Qgis-user mailing list
