[Qgis-user] Updated GdalTools
William Kyngesburye woklist at kyngchaos.com
Sun May 16 11:38:04 PDT 2010
I didn't request it directly (just a general request of plugin developers), but did you add a configuration option to set the path to the GDAL programs?  Applications (ie QGIS) on OS X don't get anything from the shell environment, like the PATH, and so won't find the GDAL programs in the GDAL framework (and on older systems for those that compile a non-framework GDAL, /usr/local/bin is not in the default PATH).
There is a hidden mechanism to add environment variables to applications, but most OSX users won't know about it, and there is no built-in way to configure it (just a 3rd-party pref pane).
On May 16, 2010, at 3:58 AM, Paolo Cavallini wrote:
> Hi all.
> GdalTools (AKA Raster Tools) as of v.1.1.15 has undergone some major improvements:
> - more than a command can be executed simultaneously
> - in the meantime, QGIS can still be used (useful for long-running commands)
> - there are 2 more notices for the user:
> . one that warns if one is trying to close a running tool
> . one at the completion of the execution
> When a long running command ends, the second message pops up in the foreground.
> https://trac.faunalia.it/GdalTools-plugin/
> Thanks to Giuseppe for the coding!
> Feedback welcome.
> All the best.
> Paolo Cavallini: http://www.faunalia.it/pc
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
