Sv: Re: [Qgis-user] Creating polygon from points in csv file
Ulf Almroth
ulf.almroth at lillabjoern.se
Fri May 21 15:01:46 PDT 2010
Using an attribute is agood idea. A lot of measuring devices
generating ascii files with coordinates, e.g. various type of surveying
equipment and coordinate measuring devices
for industrial use produces file that basically look like this:
featuretyp, X,Y,Z,pencode
A sample file from a steroplotter used for mapping arial images with
sterooverlpa looks like this:
BBH 1868462.502 7323256.557 5.266 21
BBH 1868458.596 7323265.540 5.266 22
BBH 1868452.062 7323262.698 5.266 22
BBH 1868455.967 7323253.716 5.266 22
BBH 1868462.502 7323256.557 5.266 23
BBH 1868359.027 7322916.789 6.259 21
BBH 1868357.951 7322925.557 6.259 22
BBH 1868351.513 7322924.767 6.259 22
BBH 1868352.589 7322915.999 6.259 22
BBH 1868359.027 7322916.789 6.259 23
where 21 signifies the styart of the polygon (or line) and 23 the
end.
Regards
Ulf Almroth
----Ursprungligt meddelande----
Från: goyodiaz at gmail.com
Datum: 2010-05-20 00:03
Till: "MORREALE Jean Roc"<jr.morreale at enoreth.net>
Kopia: "qgis-user List"<qgis-user at lists.osgeo.org>
Ärende: Re: [Qgis-user] Creating polygon from points in csv file
El mié, 19-05-2010 a las 22:20 +0200, MORREALE Jean Roc escribió:
> Hi Goyo,
> I would like to test your file but I can't not extract the file from
the
> tar.bin, could you resend it using a more common format ?
The original author, Pavol Kapusta, uploaded (a new version of) it to
the contributed repository so you should be able to install it using
the
plugin installer (plugins > Install python plugins).
Please send bug reports and suggestion here or to me.
> Your modification is great as it would solve a major pain I've been
> dealing with my tacheometer's output, it is a basic ascii file where
> every record is a point to which you can append a codification.
> For now we've to connect the point by hand, automating this task
would
> be a relief (and a lot less error prone).
> Would it be easier to make a correct geometry by assigning a code to
the
> point telling if it's the opening or the closure ? Or just following
the
> incrementing point number would be enough to get a correct geometry ?
As for now the plugin assumes the points are in the proper order.
Sorting them by an attribute sounds like a good idea to me, I'?l think
about it.
Goyo
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
